Everything 101
A project log for Hackaday.io Project
Follow for the 'Hacklet' and latest news about hackaday.io
richard-hogbenRichard Hogben 03/07/2014 at 19:19306 Comments
Your Hackaday Profile is the best way to express yourself. Fill it out completely so people can learn more about you.
Basic profile info
When you first sign up to Hackaday.io, we ask you to enter some basic info about yourself such as: your username (which becomes your vanity url), location, a word or two about yourself, tags for others to find you easily, and external links to your profiles on other networks. You can always change these by going to Edit my Profile
My Projects & Projects I contribute to
When you Add a Project, it will appear on your profile under the section My Projects available under profile drop-down menu. We'll highlight only the most liked projects and the rest will be visible by clicking on View all projects.
We highly encourage collaboration. That's why we have a contributors list when creating projects. If you are part of a project, we'll highlight that project on your profile.
Things I've built
You can tell Hackaday.io users about your projects in two ways: by adding a project, or by listing them on your Things I've Built section. This section is for projects that you don't have enough material to document. All you have to do is upload one small image and write a brief summary about your project.
My pages
Whenever you have something to say to the world, or just want to rant, you can Create a Page about it. Think of this section as your personal blog. Like projects and profiles, pages also have comments feature.
Mentions
You can be mentioned by or mention another user by using the '@' followed by username of the user. Mentions can be made in many areas across the Site, such as: Comments, Messages, project logs, Details, Stack etc. If a user mentions you anywhere on the site (except Messages), you will be notified via email and on your Private Feed.
It's 2016. There was no way we could name this guestbook. Write a bit on your profile, on other's profiles, say something useful or give feedback.
What are you working on? What cool things have you built? Document them, share with the universe, get feedback, find collaborators.
Basic project info
When adding a project, we ask you to enter some basic details like name of the project, photos, a short description, tags so people can discover your project, external links (i.e. project homepage, GitHub, social links, etc.) and team members.
When you add team members to your project, these members will be able to update some parts of your project page, like the project logs. They will also appear on the Team section of the project page. Fellow users who would like to contribute can also request you to join.
Private Projects
You can create your project in private mode if you are not yet ready to show it to the world. A project can be made private by simply changing the tag inside Edit project page to 'PRIVATE'. All projects are public by default.
Details
The project details section is where you can write everything about your project. Most people use this section to explain how their builds work.
Project logs
Logs are a great way to keep your project followers up to date. It logs the progress of a project from start to finish.
Components
The components list is an easy way to show all the parts/items you used in your project. It also lets you add the quantity of parts used.
Build Instructions
If you feel like sharing how to build your project in a step by step guide, Instructions is the tool you are looking for.
As the name suggests, the project discussions section is where visitors can leave feedback or ask questions. This section is available for individual logs and Build Instructions of a project too. Whenever someone leaves a comment, you'll get an email notification (assuming you did not disable email notifications) and you'll see it on your Private Feed.
Mentions
Any project can be mentioned by using the '#' followed by the project name. If your project is mentioned, you will be notified on your Private Feed and via email. Projects can be mentioned in all the areas where users can be mentioned.
Gallery
If there's one place you want to go to view all media related to a project, this is it. You can view, share and download images and videos of a project by clicking on 'View Gallery' right below the main project photo.
You can follow projects and people on Hackaday.io to stay up to date. Just look for the Follow button on the project page or the person's profile.
When you follow someone, you'll see activities from them on your Private Feed page. This works the same for other user's projects; follow the ones you like and you'll know about any updates to the project, the addition of new build logs, etc.
Just saw a cool project? Like it! Likes are a way of saying "This project is cool". If you collect more likes, your project will eventually have more visibility. Users can sort projects by 'Most liked' in the project listing page.
Hackaday.io uses Redactor editor to make editing easy. It is a toolbar that is available as you scroll down the page. All options have helpful tool-tips.
Features of the editor are:
Links
You can turn any text into a link by using the context menu. To do this, simply select the text, and click on the link icon of the context editor.
Images
As with links, you can add images from the context menu. But a simpler way is to just drag and drop images from your device!
Copy & Paste
One of the coolest things about the editor is that you can copy any styled text from another page (i.e. your blog) and paste it to Project Details, Logs or similar pages and it'll match our styling. This should work perfectly in most cases, but be sure to double check before publishing your content.
One small thing about copy & paste: if you do this from a page with images, your images will not be uploaded to Hackaday.io. Instead they would be linked to the original page. In most cases, this is not a problem but if something happens to the original page, your images won't be visible on Hackaday.io either. To prevent this, you may want to add your images manually.
Videos
Have a video you want to add to your project or page? If it's hosted on YouTube or Vimeo, simply get the URL of your video and paste it in the editor when you are adding your content. After pasting the URL, pressing Enter will turn the link into an embedded video.
Code snippets
A code snippet can be added by clicking on the code icon and choosing the language. This can later be edited as well.
Styling
There are many options for styling your text. The styling options can be applied after entering the text. Options such as bold, italic, headers, tables and lists are available for representation. Separators and 'Read More' are available for organizing the text well.
Rich text editor
CarleneLee78 wrote 02/11/2025 at 13:05 point
Walter Hynson wrote 02/03/2025 at 05:08 point
I like to build cnc devices that use some version of grbl, I am a retired Eng Tech with experience in the development of space flight hardware. My speciality was  assembling circuit boards that did not fall apart on the vibration table which required specific methods of mounting and soldering electronic parts, today I spend my time building drawing machines. when the drawing is complete I will paint it using watercolor ,acrylics and gouache depending on the need.
KenS wrote 01/07/2025 at 20:46 point
    I have a Color Organ Project on hackaday.io https://hackaday.io/project/201860-stereo-7-band-color-organ but when I search on "Color Organ" on the hackaday.io site https://hackaday.io/search?term=%22Color+Organ%22 my project does not show up.  Is there any way I can get it to show up?
    Search Engines can find it on hackaday.io https://duckduckgo.com/?q=%22color+Organ%22+site:hackaday.io so why can't hackaday.io find it on it's own site?
pfmahoney wrote 01/01/2025 at 18:32 point
I’m trying to modify the Open Gamma project which uses a 36V silicon photo detector to instead use an 800V photo multiplier tube because they are selling a bunch of Hamamatsu PMTs which were taken out of the supercollider in CERN when they upgraded and are now pretty cheap on Ebay (I got one for $16).
cicamargoba wrote 12/27/2024 at 15:16 point
Hello. I've already built a board with T113S4, all works fine, but I have problems with audio codec, seems like need a different clock configuration
Dźwiedziu wrote 12/26/2024 at 09:06 point
How to change account authorization from OAUTH to password?
CanHobby.ca wrote 12/24/2024 at 23:29 point
What is the best size for the background image?
KenS wrote 12/10/2024 at 20:30 point
How do I change the Text Color to Black?  I've tried things like
        <strong style="color:BLACK">Red</strong>
    and
        <font color="BLACK">Red</font>
    but it KEEPS GETTING REMOVED when I Publish it.  Frustrating.
endywilms wrote 12/01/2024 at 01:14 point
123
James Pilgrim wrote 11/28/2024 at 23:51 point
I changed the title of our main project.  That caused the URL to change.  Is there a way to retain the original URL, while still changing the title?  I tried to change from https://hackaday.io/project/195042-diy-golf-launch-monitor to https://hackaday.io/project/195042-pitrac-the-diy-golf-launch-monitor.   Can you manually set the URL for your project?
Thank you in advance for any help!
Ken Yap wrote 11/29/2024 at 00:41 point
Actually you only need the part of the URL before the first hyphen in hyperlinks. In fact even if you substitute garbage after the first hyphen it still takes you to the correct project page. So even if an old URL is used after you have renamed the project, it will still work.
James Pilgrim wrote 11/29/2024 at 02:33 point
Ah ha - thank you!  That works great.  Clever. :)
MasterOfNull wrote 11/29/2024 at 17:44 point
You can get pretty nice shortened links built into HAD.  I don't know how to link short links to pages though.
Summing up, http://hac.io/o/399 goes to project 399 and so forth.  Suitable for direct inclusion in QR codes within the project.  You can remove http:// so your QR code becomes just "hac.io/o/399".  Get shorter than that...
https://hackaday.io/page/6012-short-links
prakashsapute2 wrote 03/29/2024 at 20:44 point
Hi
c.jason2016 wrote 03/22/2024 at 09:24 point
Je veux des pièces
Renfro wrote 03/02/2024 at 15:37 point
Anyone know a simple method of changing the grey screen font to a lighter shade or to select a high visibility 'theme'?  The common dark grey on black background requires me to highlight text I wish to read on hackaday.  Very annoying.
rjkopecky wrote 02/06/2024 at 19:32 point
With the PEMF projects is the coil wire bare or is it insulated?
oklanohwer wrote 11/07/2023 at 14:43 point
hi
Michael Gardi wrote 10/24/2023 at 04:49 point
Why are project views updated so infrequently?
Ray Teller wrote 10/20/2023 at 09:34 point
I'm getting notification for projects I never showed an interest in. How do I stop that?
Richard Hogben wrote 10/24/2023 at 18:18 point
You can unfollow any onboarding projects here https://hackaday.io/projects/hacker/316457/likesandfollows
Stephen Chasey wrote 09/13/2023 at 14:35 point
Is it possible  to export your project logs in a batch? I have a project nearing completion with 91 of them so far over the last 18 months or so and would like to export them so I can go through them easily.
Richard Hogben wrote 09/14/2023 at 16:30 point
There isn't a setting on the site to do that, but I can PM you with some options.
Hakan.Bayar.Kemal wrote 07/31/2023 at 05:07 point
Thankyou for meeting and connecting with Like Minded People, we can all inspire each others dreams!
edwardgkim9 wrote 07/26/2023 at 11:26 point
Physicist by education, engineer by heart and tinkerer by passion.
