This is the project log for the 'eye' assembly
First, I hooked up the LED to USB, because it'll eventually be on a raspberry pi.
then I needed the lens, so I looked for various round objects, and finally settled on half a christmas light globe. That was then colored in with sharpie, masked on the inside to prevent light from coming though other than the center. See some of the photos on the main build page. The next step will be an enclosure, which I will build as soon as I get the charger for my drill. completely broke at the moment, so this will be a very low budget build. It'll be about a week before I can afford the charger, so see y'all then!
