The 4 spaces
A project log for PDP - Processor Design Principles
Distilling my experience and wisdom about the architecture, organisation and design choices of my CPUs
yann-guidon-ygdesYann Guidon / YGDES 03/30/2020 at 21:320 Comments
I always keep 4 independent address spaces :
  1. Program memory (read only, high bandwidth)
  2. Data memory  (read and write, as well as scrambled access orders)
  3. I/O and Special registers (serialising, one access at a time)
  4. Registers (can sustain multiple simultaneous reads & writes)
Each is optimised for a specific purpose and things get nasty when they are mixed.
Update 20240625:
That was a starting point. I now consider it "bad" to mix que control/return stack with the data space, and the latter is split in private and public areas.
