Cleaned up a few issues with the initial prototype and with only minor exception converted the remaining components to SMD. Goal is to minimize any chance of shorting the driver against the Floodlight case.
I added the capability to jumper the Data Signal to be sourced from the nRFL24 or the input wires. This will allow testing without having to deal with the wireless.
AJ Reynolds
