Another year has come and gone, so appears has the Slim 10W floodlight housing I was using. It appears it has been replaced with a smaller version and the PCB as currently designed has issues with using connectors.
I am working on a change that will better fit in the new housing and still enable the use of the wafer connectors that I have been using. I am also moving away from the nRF24 version of the board and exploring using the ESP8266 chip instead. This will offer direct WiFi capability.
AJ Reynolds
