Finished the Soldering
A project log for ARDUINO MPPT SOLAR CHARGE CONTROLLER
An Arduino based Solar MPPT charge controller.
open-green-energyOpen Green Energy 08/12/2015 at 03:223 Comments
Purchased all the missing components and started to solder it on PCB.After few hours of work, everything is soldered.I have tested auxiliary power circuitry,everything works fine.The next task is to test the charging circuit.I will update it soon.
Rich text editor
pulimath wrote 01/18/2018 at 11:55 point
Hello Dutta
From where can I get the complete updated firmwares for this project..?
Ameer Khan VU3SQM
vu3sqm at Gmail for com
Lars Sorensen wrote 08/12/2015 at 18:40 point
WOW!
Did you design the PCB, yourself?
Will you eventually sell the PCB or just make it open source?
Can't wait to hear more!
Oh, is this the V4 or V3?
Open Green Energy wrote 08/13/2015 at 09:50 point
'Petar ' one of our team member designed it.Now there are some issues in it.Thoigh I think the issues are mostly in software part.I will solve it first. Then I will think for sell.It is obviously a Open Source project.
It is V3 controller.
