First (successful) Vanagon test
Last night, we had our first light-off and the result was very, very promising.
- Stable idle,
- Reliable starting (once I got the right setting),
- All sensor reading made sense,
- Great throttle response!
A few of the steps that got me here:
- Beefed up the rear Arm/Crank control circuit (because starter solenoids take serious amperage!)
- Verify actual injector pulses with LED on injector driver output.
- Ask the original ECU for cranking pulse duration (turns out this is totally independent of Air flow or temp.)
- Add automatic printout of injector pulse duration while cranking (helps tuning to start)
- Tweak cranking duration so choke-adjusted result matches original ECU's
- Fire it up.
- Play with global offset to maximize RPM (at first, until O2 sensor heats enough to come online)
- Continue tweaking, but now using O2 signal
- Try opening the throttle - Great result: no hesitation, RPM comes right up.
At that point my CO meter started going off, so I called it a night. Going to need to handle the exhaust gas.
What's next:
- Duct Exhaust away
- Add Temperature warning (in case it gets hot)
- Optimization routine
- Define the optimization modes. I'm thinking: warming up, warm-global, warm-local
- Define criteria for entering each mode (O2 sensor online, timer, temp, load)
- Enable the data structures for keeping track of optimization history
- Add some optimization system auto-reporting
- Add optimization modes one at a time, testing each
- Field tests.
- Take it to SMOG shop to see how we're doing.
Mike Thielvoldt
