Tweaking like a Boss
A project log for ECUality1
A light, open-source Engine Control Unit (ECU) using Arduino
mike-thielvoldtMike Thielvoldt • 04/14/2015 at 08:11•2 Comments
People, we are now
Automatically tweaking fuel levels while driving!
I have added logic for determining the appropriate times to engage 3 different modes of injector pulse adjustment, and appear to be correctly applying those adjustments.
Local v Global changes: A global tweak affects the rate of fuel injection at all RPM's and all loads (air-flows). A local tweak affects the fuel injection rate at a specific RPM and load.
Map: When I refer to a "Map", I am referring to the 2-d table representing injector pulse duration vs engine load (x) and RPM (y).
Tweaker modes
  1. Global-only adjustments based on maximizing RPM
  2. global-only adjustments based on O2 sensor
  3. local and global adjustments based on O2 sensor
Mode 1 takes over when the engine is cold and idling.
Mode 2 takes over when the engine is warm, but has not been warm for long.
Mode 3 takes over when the engine has been warm for a while and the engine has been pulling (as opposed to coasting - a state that turns the injectors off) for a minimum amount of time.
Noticeable power improvement
The seat-feel is much improved over the original ECU. I did not expect this to be the case yet, but the impetus for the project was, in large, a difficult-to-correct hesitation when accelerating using the original ECU. This has already been eliminated. Woot.
Next up:
gthielvoldt wrote 04/24/2015 at 18:59 • point
Passed SMOG, way cool!
gthielvoldt wrote 04/14/2015 at 14:43 • point
Lots of luck with the SMOG guy.
