An even better idea - Mute circuit
A project log for Muffsy Stereo Relay Input Selector
Open Source, versatile audio relay input selector controlled by an ESP32
skrodahlskrodahl • 01/15/2019 at 06:25•0 Comments
The design files are available in the files section.
To avoid pops when turning the preamp circuitry on and off, a mute circuit is really useful. So I sacrificed one input and converted the fifth relay to mute.
The functionality of this board is now:
Here's a quick and dirty drawing in MS Paint to show what I mean:
Picture of the actual board:
Below is the design in Eagle, the big red rectangles are the two separate ground planes. A Post-IT note is 76x76 mm by the way.
Here's the final build.
Arduino Code, Four Inputs and Mute
/* Muffsy Relay Input Selector
 *  Control relays using IR and rotary encoder
 *  Control external power to amp using IR and push button
  * powerState:
  *   0: Boot
  *     powerOn()
  *       startup procedure
  *       read NVRAM (relayCount)
  *       set relays to off (previousRelay = relayCount)
  *       set power amp to off, SSR = LOW
  *   1: Powered ON
  *       turn on power button LED
  *       set power amp to on, SSR = HIGH
  *       trigger relayOn(): previousRelay = relayCount + 1
  *     rotaryEncoder()
  *       increases or decreases relayCount depending on rotational direction
  *       pushbutton: Power ON/OFF
  *       does only Power ON if powerState == 2
  *     irRemote()
  *       input up/down
  *       input direct (buttons 1-5)
  *       power on/off
  *     relayOn()
  *       activates relays based on the relayCount
  *       handles relayCount too high or low
  *     powerControl()
  *       read power button, set powerState accordingly
  *    2: Powered OFF
  *     turn off all relays
  *     set power amp to off (SSR = LOW)
  *     powerControl()
  *       read power button, set powerState == 1 if pushed
  *     irRemote()
 // Libraries
 #include <IRremote.h> // IR Remote Library
 #include <EEPROM.h> // EEPROM Library
 //  Size: 1 (relayCount)
 #define EEPROM_SIZE 1
 // Variables, pin definitions
 // Onboard LED/Power LED
 #define LED 2
 // IR Receiver pin and setup
 #define IR_Recv 13
 IRrecv irrecv(IR_Recv);
 decode_results results;
 // Power button
 #define poweronButton 14
 // Pins for the rotary encoder:
 #define rotaryA 35
 #define rotaryB 34
 // Relays
 #define R1 23
 #define R2 22
 #define R3 21
 #define R4 19
 #define R5 18
 //Solid State Relay
 #define SSR 17
 // Rotary Encoder variables
 int counter = 0;
 int previous = 0;
 int aState;
 int aPreviousState;
 // Relay Array
 int relays[] = {23, 22, 21, 19, 18};
 // Relay variables
 int relayCount;
 int previousRelay;
 int relayNumber;
 // Power/Mute variables
 int powerState;
 int buttonState = 1;       // the current reading from the input pin
 int lastButtonState = 1;   // the previous reading from the input pin
 unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
 unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
 int mute = 0; // Mute on/off (1/0)
 // Setup
 void setup() {
   // Power button
   pinMode (poweronButton,INPUT_PULLUP);
   // Onboard LED
   pinMode (LED,OUTPUT);
   // Rotary Encoder
   pinMode (rotaryA,INPUT);
   pinMode (rotaryB,INPUT);
   // Reads the initial state of the rotaryA
   aPreviousState = digitalRead(rotaryA);
   // Relays
   pinMode (R1,OUTPUT);
   pinMode (R2,OUTPUT);
   pinMode (R3,OUTPUT);
   pinMode (R4,OUTPUT);
   pinMode (R5,OUTPUT);
   pinMode (SSR,OUTPUT);
   // Relay variables
   EEPROM.begin(EEPROM_SIZE);
   relayCount = EEPROM.read(0);
   previousRelay = relayCount + 1; // Start out not matching relayCount???
   // Start the IR Receiver
   //pinMode(IR_Recv, INPUT_PULLDOWN);
   irrecv.enableIRIn(true); // Starts the receiver
    * powerStates:
      * 0: Powering on
      * 1: Powered on
      * 2: Powered off
   powerState = 0;
   // Serial monitor
   Serial.begin (115200);
 * Main program
 void loop() {
  if (powerState == 0) {
    powerOn();
  } else if (powerState == 1){
    relayOn();
    rotaryEncoder(); // Include Push = MUTE
    powerControl(); // Read power button
    irRemote(); // Up, Down, Direct, Volume, MUTE, Power
  } else {
    rotaryEncoder(); // Rotary push button is temporarily power button???
    irRemote(); // Power on/off only
  * Turn on current relay
void relayOn() {
  // If relayCount has changed: Turn on the selected relay (next, previous, direct)
  // If previousRelay has changed: Turn on the last selected relay
  if (relayCount != previousRelay) {
    // Rollover 3 or 0
    if (relayCount > 3) {
      relayCount = 0;
    } else if (relayCount < 0) {
      relayCount = 3;
    // Turn off all relays, then turn on relayCount
    relayOff();
    digitalWrite(relays[relayCount], HIGH);
    // Stop IR, write relayCount to memory, start IR
    irrecv.enableIRIn(false);
    EEPROM.write(0,relayCount);
    EEPROM.commit();
    Serial.print("[http://muffsy.com]: Written \"relayCount = ");
    Serial.print(relayCount);
    Serial.println("\" to save slot 0");
   // Reset counters, output relayNumber
   previousRelay = relayCount;
   relayNumber = relayCount + 1;
   Serial.print("[http://muffsy.com]: Activated relay #");
   Serial.println(relayNumber);
   Serial.println();
   // If circuit is muted, unmute
   if (mute == 1) {
    Serial.println("[http://muffsy.com]: Waiting 1.5 seconds before turning off mute");
    delay(1500);
    toggleMute();
 * Power on amplifier
void powerOn() { // Only called if powerState is 0 (Powering on)
    Serial.println("\n       --- http://muffsy.com ---\n");
    Serial.println("The Muffsy Relay Input Selector has woken up!\n");
    Serial.print(" ** Reading saved relay state from NVRAM: ");
    Serial.println(relayCount);
    digitalWrite(relays[4],LOW);
    mute = 1;
    Serial.println("\n ** Mute Relay turned ON");
    Serial.println(" ** All input relays are turned OFF");
    relayOff();
    Serial.println(" ** Solid State Relay is turned OFF\n");
    digitalWrite (SSR,LOW);
    Serial.println(" ** Startup completed - waiting for Power ON\n");
    Serial.println("       -------------------------\n");
    // Set powerState to 2 (Powered off):
    powerState = 2;
 * Read powerbutton, turn on or off
void toggleMute() {
    if (mute == 0) {
      Serial.println("[http://muffsy.com]: Mute relay turned ON\n");
      mute = 1;
    } else {
      Serial.println("[http://muffsy.com]: Mute relay turned OFF\n");
      digitalWrite(relays[4],HIGH);
      mute = 0;
void powerControl() {
    int reading = digitalRead(poweronButton);
    if (reading != lastButtonState) {
      lastDebounceTime = millis();
    if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer than the debounce
    // delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
      buttonState = reading;
      // only toggle the LED if the new button state is HIGH
      if (buttonState == 1) {
        Serial.println("[http://muffsy.com]: Power button pushed");
        if (powerState == 1) { // Turning power OFF: All relays OFF, power amp OFF
          powerState = 2;
          digitalWrite (LED,LOW);
          relayOff();
          if (mute == 0) {
            toggleMute();
          Serial.println("[http://muffsy.com]: Solid State Relay OFF");
          Serial.println("[http://muffsy.com]: Power OFF\n");
        } else if (powerState == 2) { // Turning power ON: Last selected relay ON, power amp ON
          powerState = 1;
          digitalWrite (SSR,HIGH);
          digitalWrite (LED,HIGH);
          previousRelay = relayCount + 1; // Trigger relayOn()
          Serial.println("[http://muffsy.com]: Power ON");
          Serial.println("[http://muffsy.com]: Solid State Relay ON\n");
  lastButtonState = reading;
  * IR Remote
void irRemote() { // Start irRemote function
    // Decode the infrared input
      // Decodes the infrared input
  if (irrecv.decode(&results)) {
    long int decCode = results.value;
    Serial.print("[http://muffsy.com]: Received IR code: ");
    Serial.print(decCode);
    Serial.println();
    // Switch case to use the selected remote control button
    switch (results.value) { // Start switch/case
      case 7770223: // Relay 1
          Serial.println("[http://muffsy.com]: Button \"1\"");
            relayCount = 0;
          } else {
            Serial.println("[http://muffsy.com]: Powered off, doing nothing...\n");
          break;
      case 7774303: // Relay 2
          Serial.println("[http://muffsy.com]: Button \"2\"");
            relayCount = 1;
          } else {
          break;
      case 7766143: // Relay 3
          Serial.println("[http://muffsy.com]: Button \"3\"");
            relayCount = 2;
          } else {
          break;
      case 7787053: // Relay 4
          Serial.println("[http://muffsy.com]: Button \"4\"");
            relayCount = 3;
          } else {
          break;
      case 7748293: // Mute
          Serial.println("[http://muffsy.com]: Button \"Mute\"");
            toggleMute();
          } else {
          break;
      case 7742173: // Channel UP
          Serial.println("[http://muffsy.com]: Button \"UP\"");
            relayCount++;
          } else {
          break;
      case 7738093: // Channel DOWN
          Serial.println("[http://muffsy.com]: Button \"DOWN\"");
            relayCount--;
          } else {
          break;
      case 7745743: // Power button
          Serial.println("[http://muffsy.com]: Button \"POWER\"");
            powerState = 2;
            relayOff();
            if (mute == 0) {
              toggleMute();
          } else {
            powerState = 1;
          break;
      default:
        Serial.println("[http://muffsy.com]: Going back to waiting for IR remote keypress\n");
    } // End switch/case
    irrecv.resume(); // Receives the next value from the button you press
  } // End irRemote function
  * Mute (turn off all relays)
   void relayOff() {
    for (int off = 0; off <= 3; off++) {
      digitalWrite(relays[off], LOW);
 * Rotary Encoder Control of Relays
 void rotaryEncoder() {
   aState = digitalRead(rotaryA); // Reads the "current" state of the rotaryA
   // If the previous and the current state of the rotaryA are different, that means a Pulse has occured
   if (aState != aPreviousState){
     // If the rotaryB state is different to the rotaryA state, that means the encoder is rotating clockwise
     if (digitalRead(rotaryB) != aState) {
       counter ++;
     } else {
       counter --;
   // What to do if rotating Right of Left
   if (previous != counter) {
     if (counter > 1) { // Since the encoder gives two signals when turning
       Serial.print("[http://muffsy.com]: Rotational encoder turned ");
       Serial.println("clockwise");
        // Increase relayCount
        relayCount++;
       } else {
        Serial.println("[http://muffsy.com]: Powered off, doing nothing...\n"); // Powered off???
     } else if (counter < -1) { // Since the encoder gives two signals when turning
       Serial.println("counter-clockwise");
        relayCount--;
       } else {
   // Reset counters
   previous = counter;
   if (counter < -1) {
    counter = 0;
    previous = 0;
   } else if (counter > 1){
    counter = 0;
    previous = 0;
   // Updates the previous state of the rotaryA with the current state
   aPreviousState = aState;
