Making the PCB for the Tubes
A project log for Nixie Clock #3
a Nixie Clock using Burroughs 5870ST tubes.
mytemyte • 02/16/2018 at 20:35•0 Comments
First was to make the PCB for the tubes.  Here's a few pics of the process:
Bottom  of the board after etching and tinning.
Bottom of the board after solder mask applied
Top of board after solder mask applied
Bottom of board after cut to size
Top of board after cut to size
