Assembling the tube board
A project log for Nixie Clock #3
a Nixie Clock using Burroughs 5870ST tubes.
mytemyte • 02/16/2018 at 20:54•0 Comments
I got the components on the board and then placed one tube so I Could test it in conjunction with the main board and make sure I Was able to actually make it display OK.
This was the moment I had the necessary components on the tube board and a single tube placed and sorted out sending data to the HV5530 chips to make a digit display properly!  It took quite some time :)
And then after all tubes placed and tested.  This was a good day!
Bottom of board after assembly was finished and everything attached.
And then a couple pics of the top of board after assembly.
From the Front
From the Back
