The whole idea is to create a machine to help us recycle plastic products by turning them into usable material that you can utilize for many applications. The plastic will go into a first container to crush it into smaller pieces, then it will go to the second container where an electrical heater will melt it and to the final stage, pressure will be applied to make plastic sheets. A microcontroller will be used for controlling the motors and the electrical resistors. I still haven't decided on what I'm gonna use, an arduino, a pic or even another type of circuit (I have two FPGA's, may find some use in this project).
Kyra S
Vaibhav
Anteneh Gashaw
Robin
