A very quick update on this. I recently pushed the first release of the analog_io_lib to Github. With this library you are now able to simultaneously transmit Bluetooth Low Energy packets with nRF24 proprietary RF packets.
The interface is the same as the Serial.print API in Arduino so it is super simple to use. Check out the sample code:
Dual Mode Tx Example:
#include <analog_io.h>
#include <SPI.h>
uint8_t x = 0;
analog_io radio(P3_5, P3_6, P2_5); // CE, CSN, IRQ
const uint8_t txaddr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0x01 };
void setup()
SPI.begin();
SPI.setDataMode(SPI_MODE0);
SPI.setBitOrder(MSBFIRST);
radio.begin(); // Defaults 1Mbps, channel 0, max TX power
radio.setTXaddress((void*)txaddr);
void loop()
// put your main code here, to run repeatedly:
radio.print("TX #");
radio.print(x);
radio.flush();
delay(250);
radio.print("Beacon #");
radio.print(x);
radio.flushBle();
x++;
delay(250);
RF Receive Example:
#include <SPI.h>
const uint8_t rxaddr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0x01 };
void setup() {
Serial.begin(9600);
SPI.begin();
radio.setRXaddress((void*)rxaddr);
radio.enableRX(); // Start listening
void loop() {
char inbuf[33];
while (!radio.available(true))
if (radio.read(inbuf)) {
Serial.print("Received packet: ");
Serial.println(inbuf);
The library works both with Arduino+a nRF24 module or Energia and my MSP430 Sensor Node hardware. Check it out here:
https://github.com/analog-io/analog_io_lib
Also if you are using a MSP430 Sensor node, here is info on adding support for this hardware to Energia:
This looks simple but good! I currently use nrf24network for my space heating automation (and temperature logging) which I want to replace by ESP2866 (in SONOFF power switches) and re-use the current low power nrf24 temperature sensors. This library has just the right functionality and seems to work flawless on ESP and atmega328p. Thanks!
