As mentioned in the project description, analog.io is a powerful tool that could be used to solve a variety of world problems. Today there are two challenges that are very important for humanity, the first is improvement of the food supply and the second is water conservation. A lot of water is used to irrigate crops but there is the fundamental question of what the optimal amount of water necessary.
Here is a quick and easy IoT water sensor system that I setup using a Sensor from Elecrow, myMSP430 Sensor Node and it is connected using the nRF24 - ESP8266 Hub that I wrote about.
Here's the code:
#include <analog_io.h>
#include <SPI.h>
#define SENSOR_PWR P2_4
uint8_t x = 0;
analog_io radio(P3_5, P3_6, P2_5);
const uint8_t txaddr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0x01 };
void setup()
Serial.begin(9600);
analogReference(INTERNAL2V5);
pinMode(SENSOR_PWR, OUTPUT);
digitalWrite(SENSOR_PWR, LOW);
SPI.begin();
SPI.setDataMode(SPI_MODE0);
SPI.setBitOrder(MSBFIRST);
radio.begin(); // Defaults 1Mbps, channel 0, max TX power
radio.setTXaddress((void*)txaddr);
void loop()
digitalWrite(SENSOR_PWR, HIGH);
sleep(500);
long data = map(analogRead(A4), 0, 1023, 0, 500);
radio.print("{\"soil\":");
radio.print (data/100);
radio.print (".");
radio.print (data%100+5); // this is wrong if the tens are 0
radio.print ("}");
radio.flush();
delay(100);
radio.print (".");
radio.flushBle();
radio.deepsleep();
sleep(10000);
And the data so far:
I will update more as time goes on :)
