The Raspberry Pi is running Arch Linux ARM from N.O.O.B.S (http://downloads.raspberrypi.org/) with Lighttpd as web server.
Yana-server is a home automation home server for Raspberry Pi including a voice controlled assistance called Yana. The voice controlled assistance needs a client (Windows or Android).
Yana-server has been created by Idleman and his crew. There's a plugin system that enable more actions like controlling a MPD or reading Google Agenda (or even control your TV).
The first goal of yana-server is to be used with a Raspberry Pi and 433Mhz emitter in order to control Home Easy plugs with a simple and effective interface. Plugs can be stored in sections called rooms and can be configured with the same ID if necessary.
More coming...
RodolpheH
The µShield, ready to use !
keithl.online
blinkingthing
tomtibbetts
