My approach in developing these drones will be incremental. At first they will be simple sensors only. Then I will add communication of sensor readings, possibly through high brightness LEDs or through AM radio transmission. Then simple transport mechanisms will be added including tires on geared DC motors and later flight methods including lighter than air craft with drone style propulsion and actual quadcopter designs.
So the idea is to grow in complexity as time develops, starting with the simplest of basics and working up from there. It will be some weeks before I can solder again due to living space restrictions (oxygen tanks nearby!) so I will have plenty of time for planning of basic circuits and designs.
Les Hall
Giovanni Leal
Xasin
Les Hall
