Woohoo! My thermopiles and gas/CO sensors have arrived! And considering I've got a lot more time than I did at the NYC Disrupt hackathon to work this one out, it should go a lot smoother. What I do need though is another microcontroller board to do some tests of the device.
But in the meantime, to stay ahead of the game, there's this article to think about.
Beware the ticking Internet of Things security time bomb
One of the problems I ran into during the hackathon was the issue of doing SSL on the Arduino. The library alone would've eaten up the entire memory bank of the chip. It also would've eaten the memory up on the Teensy LC. It's the reason why we went with Temboo as our main API interface to Twilio. But that's not ideal because you can still intercept the data before it hits Temboo as unsecured. So I'm on the hunt for an easy way to incorporate and use encryption on the device.
If anyone's got any suggestions, I'm all ears.
Casual Cyborg
