Play arcade game on the UV-badge hardware!
~20 FPS @ 8 MHz.
Only 6.5 KB ROM and 145 B RAM is required.
...and remember, there is no frame-buffer! The application generates the picture line-by-line for every frame. The CPU can't store the whole picture in it's small RAM, and the LCD is "write only'' , you can't read the data back!
x-labz
