I haven't been writing updates for months now .. great. I'm currently quite busy with university and other projects, so there is not a whole lot of time left to work on the LED controller sadly.
I recently implemented some basic functionality to read and write configuration to the EEPROM. While this works quite okay, I noticed a significant flaw in my hardware design: There is no way to detect a powerdown and save to the EEPROM then, so the only way to save the current configuration is to do periodic or event-based writes. Depending on how this is implemented, it can wear the EEPROM quite a lot more than I'd like. I'll have to put a few more thoughts in how I'll accomplish that.
The next "bigger" task is to improve the reliability of the WiFi and MQTT connection. Currently the behaviour on a WiFi or MQTT disconnect is rather unknown, it might reconnect, or maybe not, or might flood the network with reconnects, I don't really know. Ideally the MQTT just tries to reconnect every X seconds when the connection is gone, and when the WiFi is gone I'd like it to behave like a Chromecast. Try to reconnect, otherwise create a provisioning access point to set up a new connection.
Basic MQTT functionality is working quite good so far, I can control individual channels or groups of channels with Home Assistant, and the controller is reporting back on what the current values are.
I hope I can find a little more time in the future, but the next weeks aren't looking promising. We'll see.
