As far as I can tell, retro games need text for three reasons: to display the score, to show off awesome FPS values, and to allow you to enter your high-score initials as "ASS". I've managed two out of three, and will soon have the last.
So far, I've only made glyphs for 0-9, F, P, and S. If I add A, the initials thing will be done. The remaining letters and symbols are just a matter of keying in some more points. There's room for refinement, obviously - the 5 and S are the same at the moment, for example.
The text is a little big, because I developed it on a scope with a tiny screen. On this one, it should be a bit smaller. That's just a parameter in the render_text() call, though, so is easily adjusted.
You can see the extra dots inserted by the interpolating DAC on this adapter. In a space-type game, they might even be mistaken for "detail."
This scope is also a little jittery; it hasn't aged well.
I also used a goto in my C code. And checked it into GitHub. It's truly liberating.
