The Mr. Fusion Home Energy Machine is almost as important as the Flux Capacitor in this project. I can afford to do only one at a time though. Since I've already created the Flux Capacitor in Scratch, the Mr. Fusion is getting the physical build. You can see the Mr. Coffee tea brewer I used as my Mr. Fusion in the image with the color concept drawing of the finished product. Another image was created in SketchUp to get a more clear image of the final.
I sanded "Mr. Coffee" off the white part and sprayed the white top area and blue lid with metallic Rustoleum. I'm going to sand it with 180 grit or so sandpaper to make it look like brushed stainless steel (which is what the Delorean is made of). Pictures are on the way.
docbrownjr
