There it is - finally soldered.
It contains a new motor driver from TI, an USB connector and two relais.
I chose an ATMega8 as MCU. This will also make the board arduino compatible.
A project log for 100$ Xray desktop CT scanner
A computed tomography scanner for your desktop
