See more information and details on the homepage: tessel.io
Websocket example in JavaScript:
/* ambient.js example */
// this example streams sound data from
// the ambient sensor every 0.5 seconds
var tessel = require('tessel');
var ambientlib = require('ambient-attx4');
var WebSocket = require('ws');
// Connect to our ambient sensor.
var ambient = ambientlib.use(tessel.port['A']);
// Open a websocket to our app.
var ws = new WebSocket('ws://awesome-app.com/ambient');
// When the connection is established
ws.on('open', function () {
setInterval(function () {
// read some sound level data
ambient.getSoundLevel(function(err, sdata) {
if (err) throw err;
sdata.pipe(ws);
}, 500); // The readings will happen every .5 seconds
});Websocket example in Python:## ambient.py example
import tessel
import ambient_attx4
port = tessel.port('a')
ambient = ambient_attx4.Ambient(port)
for sound_level in ambient:
print "Sound: {}".format(sound_level)Websocket example in Rust:/* ambient.rs example */
extern crate tessel;
extern crate ambient_attx4;
fn main() {
let port = tessel::port("a").unwrap();
let mut ambient = ambient_attx4::Ambient::new(&port).unwrap();
loop {
let sound_level = ambient.sound_level().unwrap();
println!("Sound: {}", sound_level);
}Clap-activated camera example in JavaScript:
/* ambient-camera.js example */
// this example records video from a camera
// when a certain sound level is reached
var http = require('http');
// set up camera
var cameralib = require('camera-usb');
// set up ambient sensor on port A
var ambient = require('ambient-attx4').use(tessel.port['A']);
// set a sound trigger
ambient.setSoundTrigger(0.6);
cameralib.find(function(camera) {
// stream some video when sound is sensed
ambient.on('sound-trigger', function(){
var req = http.request({
hostname: 'example.com',
path: '/upload',
method: 'POST'
function (res) {
res.pipe(process.stdout)
camera.captureStream(2000, 'mjpg').pipe(req);
});Clap-activated camera example in Python:
## ambient_camera.py example
import camera_usb
import requests
import tessel
ambient = ambient_attx4.Ambient(tessel.port('a'))
camera = camera_usb.find()
while True:
ambient.wait_for_sound_trigger(0.6)
video = camera.capture_stream(500, "mjpg")
requests.post('http://example.com/upload', data=video)Clap-activated camera example in Rust:
/* ambient_camera.rs example */
extern crate hyper;
extern crate camera_usb;
fn main() {
let mut camera = camera_usb::find().expect("Could not find camera");
let mut client = hyper::Client::new();
loop {
ambient.wait_for_sound_trigger(0.6);
let mut video = camera.capture_stream(2000, camera_usb::Format::MJPG);
let mut res = client.post("http://example.com/upload")
.body(&mut video).send().unwrap();
Kelsey
Arya
Yurii
Graham Braly
iliasam
