Not really a log but a place for me to dump some research material.
Below material from: http://www.radartutorial.eu/
Phase-increment CalculatingThe phase shift Δφ between two successive elements is constant and is called phase-increment. How large is this phase shift to reach a certain value of the beam steering?
A linear arrangement by isotropic radiating elements is looked at.
x = d · sin Θs
Because of the trigonometrical function we need a calculator anyway: Δφ =(360°·15 cm/10 cm)·sin(40°) = 347.1°. This means the radiating element no. 8 needs the phase shift value φ8 = 7 · 347.1 = 2429.7°. On reason of the periodicity of the sine function a phase shifting of n·360° is the same as 0°. Therefore we can as long as deduct 360° till there is a angle between 0° and 360° of the result. We get therefore for the phase shifter number 8 (left corner) a phase shift value of φ8 = 269.7°.A part of this phase shift is realized by the delay in the feeding line yet. |
