There should be a private section on here for notes... sketchbook.io anyone?
A project log for Active Linear Multi Element Sonar Array (ALMESA)
Active multi-beam sonar for robots and visualization... on the cheap.
eimerjosh0eimer.josh0 • 03/21/2015 at 17:57•0 Comments
Not really a log but a place for me to dump some research material.
Below material from: http://www.radartutorial.eu/
Phase-increment Calculating
The phase shift Δφ between two successive elements is constant and is called phase-increment. How large is this phase shift to reach a certain value of the beam steering?
A linear arrangement by isotropic radiating elements is looked at.
Die Grafik zeigt mehrere Strahler, die mit einer jeweiligen Phasendifferenz abstrahlen und einer grafischen Herleitung der Phasenverschiebung.
x = d · sin Θs
  • A radar set works with a wavelength of λ=10 cm.
  • The distance between the radiating elements is 15 cm.
  • We can neglect the propagation time differences by the feeder.
  • The beam steering shall be Θs= 40°.
Task:
  • Which value shall have to have the phase shifter no. 8 (on the left side) to get this beam steering?
We start with the calculation of the phase-increment.
Because of the trigonometrical function we need a calculator anyway: Δφ =(360°·15 cm/10 cm)·sin(40°) = 347.1°.
This means the radiating element no. 8 needs the phase shift value φ8 = 7 · 347.1 = 2429.7°.
On reason of the periodicity of the sine function a phase shifting of n·360° is the same as 0°. Therefore we can as long as deduct 360° till there is a angle between 0° and 360° of the result. We get therefore for the phase shifter number 8 (left corner) a phase shift value of φ8 = 269.7°.A part of this phase shift is realized by the delay in the feeding line yet.
