Experimentalist musings
A project log for SentriFarm
Solving a key farming problem: is it safe to harvest / spray / sow today? (+experiments with 'big' data in agriculture)
pastcomputepastcompute 04/17/2015 at 14:350 Comments
I figured I'd measure my ESP8266 test system, so I scrounged a 1Ω resistor and estimated the average current at 70mA, i.e. 230mW, even when just sitting on a timer. This is more than the solar panel at peak, and no amount of MPPT will help us with this, so luckily the ESP8266 has a deep sleep mode which various people have estimated < 50μA, or 165μW. Downside is until my packages get here I'm stuck with an ESP-01 which will require some precision soldering to enable deep sleep...
In the meantime I took a closer look at my logs. Occasionally analysis is no match for experimentation but I might as well do some predicting, as well as confirm previous hypotheses.
A combined MPPT / boost circuit would help with the wasted sunlight: varying the switching to track peak power of the panel, efficiently regulating to 2.4V to 95% utilise the capactor, followed by a step up to 3V3... but thats starting to sound a little over complicated.
Of course, I could revert to a AA rechargable, but that would be less interesting to me at this point. Rechargeables need maintenance: eventually they need replacing and likely to die at an inconvenient time. They also do cost a lot less.
So back to the back of the very rough envelope: lets assume a rather bad efficiency of 25% and 8 hours daylight, then 2.5V @ 0.02A x 6= 300mWH, and if we use 60s/hour for reading sensors and transmitting and assume 200mA in that small work period then the approximate power required is (.983 * 165μW + .017 * 0.2 * 3.3) x 24 or 273 mWH so we have 10% margin even at those extremes.
I should have done that calculation more explicitly before, luckily it works out OK. But regardless, to date this has been useful as an exercise for getting my lab back into shape and getting my mind back into the swing of working with electronics.
Rich text editor
