So I just realised there seems to be no easy way to back up this area. Also I might be in danger of flooding too much information.
I think I'll need to do some housekeeping and tidying soon; I'll possibly start putting the design information into the git repository instead with a summary here, and for extended project logs I'll probably use my block for extended detail and link to there with shorter updates...
My sensor core now build ans works as a one-shot wifi scanner. Now I can concentrate on the sensor readings and timing algorithm.
