5v, 3v3 --> Bus Pirate of course
A project log for SentriFarm
Solving a key farming problem: is it safe to harvest / spray / sow today? (+experiments with 'big' data in agriculture)
pastcomputepastcompute • 04/26/2015 at 09:22•0 Comments
So of course the Digispark needs 5V as I rediscovered when I went to wire it up. I had always run it on USB power until now, and unlike some of my other gadgets it doesn't have a 3v3 converter. Well, it is small. I don't have any spare level converter boards and don't want to wait.
Then I remembered my Bus Pirate. Problem solved...
(Update)
So the bus pirate is working well. (Apart from only having one...)
picocom -b 115200 /dev/ttyUSB0
im5 1 1 2 1 2 2
Wva%:6A
[0x42 r:1][0x01 r:1][0x02 r:1][0x03 r:1][0x06 r:1][0x07 r:1]
This produces SPI reads that match the default values in the datasheet. Seeing as this is the first time I ever used SPI , this is a win :-)
/CS ENABLED
WRITE: 0x42
READ: 0x12
/CS DISABLED
/CS ENABLED
WRITE: 0x01
READ: 0x09
/CS DISABLED
/CS ENABLED
WRITE: 0x02
READ: 0x1A
/CS DISABLED
/CS ENABLED
WRITE: 0x03
READ: 0x0B
/CS DISABLED
/CS ENABLED
WRITE: 0x06
READ: 0x6C
/CS DISABLED
/CS ENABLED
WRITE: 0x07
READ: 0x80
/CS DISABLED
This could get quite involved, so I might set up a separate place to write about it.
