I'm giving away 4 Micro:Gamer boards!
A project log for Micro:Gamer
Portable game console based on the Micro:Bit
fabien-chouteauFabien-Chouteau • 05/16/2018 at 21:43•5 Comments
I just received the first batch of Micro:Gamer rev-B from SeeedStudio. It is the first time I have a design made in series, a very small series but a series nonetheless :)
There's a few changes in the design, the first one being the SMD version of the micro:bit connector which allows for a better looking board. I also added a power slide switch and slightly moved some components.
As stated in the title of this post I'm giving away 4 of the boards. I have no use for 5 so if you have a cool idea for a game or feature that you want to try, I will be happy to send one to you (depending on the how much it costs, I might ask you to pay for shipping). Contact me using the private messages if you are interested.
nardev wrote 05/21/2018 at 02:18 • point
im teaching kids programming with micro:bit, in one orphanage in Bosnia. Would be great to get one.
Fabien-Chouteau wrote 05/21/2018 at 11:40 • point
Hi nardev, let's discuss by private message.
Fabien-Chouteau wrote 05/17/2018 at 18:58 • point
It's the good people at SeeedStudio that told me about the SMD connector, a game changer for micro:bit projects.
I totally agree with you on the PCB art. But I'm no Saar Drimer :) so I would need some help on that.
For the second switch I will avoid that to keep the project as simple as possible. You can always disable the sound from software.
deʃhipu wrote 05/17/2018 at 22:01 • point
I think that some simple doodles could work very well on it, as a monochromatic silkscreen. Perhaps you could ask the teachers? I think they kids could be very proud that their art is on it!
deʃhipu wrote 05/17/2018 at 07:00 • point
Wow, I didn't realize there is an SMD version of that connector! That makes things much nicer!
You have a lot of empty real estate on the PCB now, have you considered adding some PCB art there? Maybe some doodles?
A second switch for the speaker might be useful.
