I have had nothing but trouble getting the hub to connect and stay connected to my wireless router. I recently figured out the cause. I had placed my hub about ~5 ft from my router, and evidently that was close enough to saturate the hub's wifi radio. I moved it to the other side of the room and it has worked perfectly since then.
agm777
