This is an initial version. Expect it to be buggy.
Requires .NET v4 and Arduino IDE v.1.6.0 (min).
Arduino released version 1.6.3 which moved the compiler tools back to the application folder. Version 0.3 of IDE4Arduino is now compatible to this Version (so 1.6.0 to 1.6.3 without v1.6.2, which was maybe released on error ?!?).
Also small bug fixed in the main code.
<-- Download Link for pre-build installer and code on GitHub on the left
as it looks like there are some problems:
with Arduino 1.6.0 I suddenly started getting a strange error from the gcc compiler; updating to 1.6.1 helped
when going to the arduino page I realized there is already a version 1.6.2 released
the Arduino 1.6.2 comes with a different folder layout, and without doing some changes cannot be used that easy... I will look into this later.
Source now available on GitHub
<-- Download link is on the left
Initial Release:
* most of things working
* upload only with build in uploader (avrdude and bossac)
* terminal window not working at the moment (comming soon)
* download link on the left side
Once the code is a bit cleaned up and I don't need to be ashamed to show it, it will land on GitHub.
Looking good, i'll prolly give it a whirl over the coming weekend (because if theres one thing i could use its that documentation/help pane) and report back here, keep it up! :)
