Just to keep you up to date, I will be working on fingertip force and temperature sensors as part of this effort. I will be using force sensitive resistors in voltage dividers and thermistors in voltage dividers on the ADC pins of an ATtiny84 and displaying the output on a set of transducers such as thermal outputt resistors and LEDs for the force output.
Les Hall
