Above you can see the new battery pack that I 3d printed and the programmer with the broken traces because the adapter board I soldered to it broke off. I think I can fix the programmer with some careful soldering since a header was provided mid-board. Once that is done I'll be ready to perform a test run game of Circuit Wars!
