Assembling Muribots
A project log for Muribot Robotic Educational Platform
Muribot is a low-cost, easy to use, open-source and feature-rich learning tool for exploring programming, robotics, and STEM fields.
crypto-neoCrypto [Neo] 04/09/2015 at 17:240 Comments
Here's a look at how I assemble my work, I do 99% surface mount components, usually 0402 capacitors and resistors, leadless packages and smaller BGAs. All without a scope ;).
Here's a look at my setup, it's just a simple rework station and an ESD mat.
A bare PCB, the one picture is a A04 revision.
Here is the same PCB with the ICs, USB port, and Power switch
And the same PCB with all the capacitors and resistors added.
A isometric shot after adding the 8 IR/Light sensors
The completed PCB with the motors and rechargeable battery
The battery and motors in their housing, and...
The completed unit!
Loading the bootloader firmware
Loading the encoder module firmware
And loading the diagnostic software! This unit is ready to go through final testing and QA!
