SSID Coder Demo
A project log for SubPos Positioning System
A "dataless" Wi-Fi positioning system that can be used anywhere GPS can't.
blair-wyattBlair Wyatt • 03/24/2015 at 11:39•0 Comments
So let's do something fun. Here is an SSID encoder/decoder that implements the SSID coding scheme (sps_ssid_coder.c). To build run gcc -o sps_ssid_coder sps_ssid_coder.c
If you can think of ways to optimise the decode_ssid function please fire away.
Edit: it prints the correct hex string representation out now for use in realterm.
It should yield the following output:
See Coder Update for the latest code.
