Here is a javascript SSID coder for you to use to use with the Android App:
http://www.subpos.org/index.php?title=Javascript_SSID_Coder
This can now be used in conjunction with ESP8266 node(s) to determine your position.
I will have the Android API released over the next few days along with more documentation (the SubPos standard).
