The parts for the first run of PCBs have arrived:
Edit: PCBs arrived!
Test fit:
So purple! Thanks hackaday!
Edit2:
I haven't soldered SMD stuff for a while, so I'm definitely out of touch, especially for lead free SMD hand soldering.
The first board is done:
It all powers up, but I have some programming to do now.
Connecting to MPLAB PICkit 3... Currently loaded firmware on PICkit 3 Firmware Suite Version.....01.36.10 Firmware type..............Enhanced Midrange Now Downloading new Firmware for target device: PIC18F25K22 Downloading AP... AP download complete Programming download... Currently loaded firmware on PICkit 3 Firmware Suite Version.....01.36.10 Firmware type..............PIC18F Target voltage detected Target device PIC18F25K22 found. Device ID Revision = 5 The following memory area(s) will be programmed: program memory: start address = 0x0, end address = 0x7fff configuration memory Device Erased... Programming... Programming/Verify complete
Hello world:
Blair Wyatt
