Piecing the frame together
A project log for Internet Split Flap Weather Clock
Internet controlled weather station that shows the current weather with a split flap display.
sephendevosSephenDeVos • 03/24/2015 at 11:34•0 Comments
Space is tight so everything has a fixed place. First i used tie-wraps to secure the wiring but then the frame wouldn't fit in the case no more, now i'm using very strong yarn which works fine.
A ethernet cable just fits in its slot
