Drilled eight 5mm holes by hand about 3mm deep in the case and the front panel. Then glued in some 5x3mm magnets that i bought from aliexpress. after that i primed and painted the case. I think the paint will scratch from the magnets. But a black marker will fix that.
SephenDeVos
