The cartridge dispensing method is still up in the air. We brainstormed 3 ideas - plastic film with holes, a rotating drum, and a reciprocating plate. In each of these designs, the cartridge has a tube which holds the pills and a dispensing mechanism (except the motor, which is part of the machine). Below are the initial concept drawings:
