I swapped out the DS18B20 temperature sensor since it was messing up my timing in my sketch and replaced it with LM35 and its been working great.
Since the temperature sensor was the last bit of hardware I thought I should start to pick out an enclosure. With every new project I like to try new/different things so I picked a large desktop enclosure.
One that would have plenty of room for all of the components to fit into. The thing about a big enclosure is that it will require a larger then I would normally be able to afford PCB. I really do hope I win some OSHPARK vouches so I can order my dream PCB for this and other projects and not have to worry about size
