Working on the arrangements to make this happen. This would be the ideal place to show the system and interface with actual end users. I already follow the SteamUniverse discussion boards to best address the concerns and questions that arise there, but nothing beats the feedback form an actual Gamer using the system.
The event fortuitously takes place on August 7-9, so my 3 prototypes will be put through the wringer there before being shipped off to Hackaday (or specifically Supplyframe) by the 17th.
Check out http://thegamecon.com. Even better, if you can be in Galveston on Aug 8-9 come and play some games.....
