Coming soon ...
Play and create games using the BBC Micro:bit
Coming soon ...
Thanks to the Bluetooth capabilities of the BBC Micro:bit we can use the Bit:boy to play some games like Nemesis, Super Mario or Pang running on an Android device.
Here you can see the Bit:Boy displaying and rotating a 3D Cube in real-time. I was well impressed to see it could still run smoothly and beyond 60 fps.
This is the current state of the project. So far it's possible to play some Arduboy and Gamebuino games. It's not 100% compatible with those systems because that's not the goal of this project. I am working on it's own API and I hope it will be easier to use. It runs at 60 Fps or more :) Check out this video to see it in action if you have a chance:
