The project uses the ILI9341 16bit display and a touchscreen for input. All buttons will be virtual except the power on/off. While working on the ILI9341 LCD library I also coded a simple Paint application to test everything working together:
The library code is released as open source, details on http://www.pocketmagic.net/ili9341-touchscreen-lcd-library/
Radu Motisan
