After drilling and cutting my teensy-lc arrived from HAD, and the servo arms were literally a headache. I found a nice design for a glue stick linear actuator, and I am incorporating the teensy as the (or an alternative) controller. I need to find out if I can use a common send pulse for multiple range finders to reduce pin count.Will update as i learn more :)
haydn jones
