Everybody have a lot of USB power supplies. Too much... I used one as Led tester. You need a standard 12v male plug and an usb charger.
Yes, delete it Cancel
You are about to report the project "Cheap Led tester", please tell us the reason.
With 1,8V leds, your idea is necessary. Précision is necessary.
