Also got it to work with NeoPixels, because one light might just not be enough sometimes.
A tool to make the invisible visible, to paint with temperature.
The Neopixel version of the weather wand s pretty fun too, self portrait in heat.
Weather Wand with RGB LED
Weather wand with NeoPixels
Nice and useful application, congrats!
You may want to try a TMP112 as a temperature sensor, you'll be amazed by its sensitivity.
I will give it a shot, anything that speeds up the response rate and resolution is going to help and that thing has crazy good resolution. I have a MCP9808 from adafruit I have been playing with but the tmp112 might be even better. Thanks!
