The purpose of this project is to build a dimmer switch with integrated Jasper project functionality.
Top Level Requirements
- Replaces a standard 120VAC dimmer switch (mechanical and electrical interface).
- Jasper project functionality
Flow Down Requirements
- 120VAC Input
- 120VAC dimmer switch compatible output, 10A
- Minimum Raspberry Pi compute capability
- Capacitive Touch Interface
- Microphone - Should be able to work across a room
- Speaker
Component Requirements
- 120VAC Input
- TBD
- TBD
- Compute Capability
- Intel Edison
- 3.15V to 4.5V VSYS
- Audio
- PCM2901? USB Codec
- Output
- 0.5W, 8ohm speaker
- TPA2005D1 Class D Audio Amplifier
- 2.5V to 5.5V VDC
- 1.4W into 8ohm
- Input
- Sparkfun INMP401 MEMS Microphone Breakout
- 1.5V to 3.3V VDD
- Touch Interface
- MPR121QR2
- 2.5V to 3.6VDC
- Slider Interface?
- MPR121QR2
