This project is nearing completion. Front panel for the display is cut, as well as drilled for switches and buttons. The oscillator mount points are drilled; the back panel only needs a hole for the power cord. Lucite is cut for the display window. Remaining work is re-spraying the front panel, tinting and mounting the Lucite, wiring switches and pushbuttons, and mounting everything inside the case.
I would estimate another 2-3 hours' work until completion. I will add some photos to the gallery as well showing my progress.
