Although I reference The Smart Garden as an Arduino controlled project, the truth is that I still have not decided which development board I am going to use. I am still leaning towards the Arduino because I spent a lot of time working on code in the Arduino IDE to control the plant robotics, but the Edison and Pi are just so intriguing.
Frank Vigilante
The arduino certainly has the biggest community so it would be the easiest to get up and running with. But I agree, the Raspi and Edison are interesting options to experiment with. The Edison is fairly new to the game, but there has always been a struggle for developers to decide between Arduino and Raspi for a project.
Sometimes what it comes down to is the Arduino can do a lot of signal output changes quickly whereas the Raspi is somewhat slower at it. As in, if you need to switch a pin on and off really fast, the Arduino can accomplish it while the Raspi struggles. But the Raspi has its own advantages such as easy as pie connectivity (plug in a wifi adapter and boom you have wifi), you can host web servers, etc.
But now with boards like the ESP8266 being so cheap and providing a quick and easy way for an Arduino to communicate over WiFi, the Arduino solution is becoming the more popular.
Good luck, love the idea. I have been working on something eerily similar haha, but I'm in early stages.
p.s. The Pi is a 2
